Applicable but let's be honest. Would I embarrass myself by telling I made that mistake?Loose oil filter?
It's a plug alright but not a "freeze" plug. Eagle eyes might be able to make out that is is just 3/8" in diameter.Freeze plug
Winner winner chicken dinner!Dip Stick tube plug.
Crankcase pressure is separate from the pressure in the oiling system where the gauge takes its reading. My oil pressure never faltered a bit during all this.Let me guess...cookies.
So the question begs, how the hell were you building normal oil pressure? Seems like it would have least been low.
Nope not cookies. Something legit.Let me guess...cookies.
That's interesting, I always assumed it was one big pressure chamber...for the most part.
I did call Mark. I figured if anyone knew how to deduce a blown engine he'd be the guy! Just like here, he went line by line of all the possibles. Had us both shaking our heads. If only I had known about your trials last week!Late to the party, but I had the exact same problem when we first put the 65 on the road. You should have called me Terry, I could have saved you minutes of frustration!
Had I not known the problem based on my experience I would have guessed you let Mark near your engine during the build.
It's a spacial volume thing. All the oil passages throughout the engine are quite small in actuality. The oil pumps enough volume to keep it full and then the pressure behind it builds it up to what you see on the gauge. in the vast openness of the pan area and exposed lower block very little pressure builds. The better your piston rings seal you get a touch more pressure down there which is the reason engines need crankcase ventilation to keep it low enough not to hurt itself fighting it. During this whole ordeal one concern was that I had a broken oil control ring allowing oil to get past and into the combustion area. This could also allow combustion pressures into the pan which could cause oil to blow through the PCV system into the intake as well. That's why at one point I did this to see what was a happening.That's interesting, I always assumed it was one big pressure chamber...for the most part.
