thanks, sounds like we have a few guys on here that have had experience with them. That is good for meI would go with modern driveline. They mostly deal with mustangs, everything I've bought from them fit perfectly. Good luck on your project!!!
the Quicktime Bell for a 351M/400M, 429/460 says it will accept a toploader, TKO and a T5? Can't imagine why anyone would try. T5's can be broken by a strong 302!Doubt you could even find a bell to mate a t5 to a 429?
just don't use enough tire to get traction!Crazy. No way I would try it. I'm concerned about my t5z behind a warmed over 351w.
A rebuilt T5 can be had for well under a grand. They typically can be found for less than a few hundred bucks in need of some kind of repair. I am at about $500 for a fully rebuilt unit. Upgraded in areas even. If i break it and need to do some work I would likely still be at under half the cost of a TKO. That's how I would be money ahead. Now if you buy a new T5 and if it someday needs work and you can't/don't work on it yourself its a different story.Really Horseplay? $200 is all my TKO cost over the T5.
Money ahead? How?
I'm not sure those guys running around on the street with the T5 are fine. I can only tell you that after a couple hard shifts with mine now my second gear wants to grind.
In the late 70s early 80s we chose between the T10 and toploader. I can tell you from experience that just like the T5 the T10 needs some work on the internals before it held up to anything that got any abuse like a teenage driver.
The T5 is a good transmission, but needs some help before it is even close the the TKO. Period.
For the extra money to get a built T5 you might as well go with a TKO.
I can say this since I have both with darn near the same power under the hood.
In the years gone by I had both the Top loader and T10. I know there are examples of both Ts behind serious power, but that is due to stronger internals being installed!
So, I'm not bashing, just stating facts based on personal experience.
If we keep the 67 we will be swapping the T5 out in favor of the TKO.
Sent from my XT1030 using Tapatalk
