"jmbour66" said:Do I need to cut the pink wire at the ignition and replace it? If so, how do I get the ignition out of steering column?
"Mach1Rider" said:The ign switch is mounted onto the outside lower part of the colume and is held on by 2 nuts.
The resistor wire is in the main harness loom located behind the inster cluster.
Remove the cluster and unwrap the harness and look for a looping pink wire.
