Dne'
Hi everyone! Thank goodness all the holidays are past, relatives have gone home, etc. and its back to work! ep
This is my rear end! (NO, not that rear end! :rof)!
I'm installing the Crown Victoria disc brakes soon. Herb, the man that overhauled my engine is coming over to help. He's a machinist, and he's going to do the machining stuff!
Anyway, I got a pretty good deal on the rear disc setup for about 100.oo! finally a decent deal from ebay!
I guess my question would be: do I go ahead a remove the third member, or just leave well enough alone? I was able to drain the fluid out the end of the axle tube by lifting one end. The fluid looked ok, no metal flakes, etc., I have the brake lines, and after all the cutting, grinding, then I'll paint it, the put it all back together. I will be replacing the axle bearings and axle seals.
This is obviously one of the rear disc components. I know pretty much what to do, just curious if anyone has done this swap, and have any suggestions?
