My Wife's Diamond Blue Coupe (A Daliy Driver)
Re: My Wife's Diamond Blue Coupe
With help of Gary, Some great progress has been made.
Shock towers were welded
<img src="http://www.stangfix.com/testforum/gallery/7/468-290311064724-77221778.jpeg" />
<img src="http://www.stangfix.com/testforum/gallery/7/468-290311064726-7723186.jpeg" />
Engine is in
<img src="http://www.stangfix.com/testforum/gallery/7/468-290311064723-7721620.jpeg" />
Water pump is on
<img src="http://www.stangfix.com/testforum/gallery/7/468-290311064718-77192219.jpeg" />
Transmission and Emergency brake hooked up
<img src="http://www.stangfix.com/testforum/gallery/7/468-290311064728-77252117.jpeg" />
<img src="http://www.stangfix.com/testforum/gallery/7/468-290311064727-7724398.jpeg" />
Drive shaft is on (i have another one I am about to send out for balancing and then I will detail it.)
<img src="http://www.stangfix.com/testforum/gallery/7/468-290311064720-7720269.jpeg" />
More progress
Transmission filter and gasket was changed and oil was added.
<img src="http://www.stangfix.com/testforum/gallery/7/468-310311072046-77331370.jpeg" />
5 quarts of Royal Purple were added and the oil pump was primed. Rockers were adjusted.
<img src="http://www.stangfix.com/testforum/gallery/7/468-310311072044-77321740.jpeg" />
Distributor is in and spark plug wire made and installed. A base timing was set
<img src="http://www.stangfix.com/testforum/gallery/7/468-310311072041-77302055.jpeg" />
Now waiting for parts from several vendors!
All lights are now working. Sequential / Chase tail lights were added (from www.meter4it.com )
<img src="http://www.stangfix.com/testforum/gallery/7/468-030411121552-77691736.jpeg" />
<img src="http://www.stangfix.com/testforum/gallery/7/468-030411121550-77591558.jpeg" />
Now waiting for some parts to arrive.
Be careful those bulbs don't get to hot with all working. They work good and look good....I have heard of heat problems with so many 1157 in a small light. I have always used LED's so I have no personal experience.
just a word of advise, when I added the Cougar tail lights which includes 3 bulbs, I had issues with the turn signal switch. I actually fried it. I have since researched the Cougar wiring because they use the same TS switch. I see that they used relays, which I added to my car when I replaced the TS switch and I haven't had any more issues.
More progress,
Front end alignment done to OpenTracker specs.
caster is +2.5 degree
Camber -0.5 degree
Toe end is 1/8 inch
Fuel sending unit and harness in. Carburetor and shocks installed,
The rear seal was leaking, so it was removed
<img src="http://www.stangfix.com/testforum/gallery/7/468-050411100141-77841446.jpeg" />
New Seal
<img src="http://www.stangfix.com/testforum/gallery/7/468-050411100142-77851774.jpeg" />
New Seal Installed
<img src="http://www.stangfix.com/testforum/gallery/7/468-050411100145-7786847.jpeg" />
all done
<img src="http://www.stangfix.com/testforum/gallery/7/468-050411100138-77831292.jpeg" />
Now waiting for the power steering pump and a few more parts to come,
H-Pipe came in and is installed.
<img src="http://www.stangfix.com/testforum/gallery/7/468-060411194408-77882300.jpeg" />
The engine now runs and the gauges work. The oil sender went out and need to get another.
hopefully more pictures soon.
Took some pictures today at lunch.
Seat is not yet bolted down
<img src="http://www.stangfix.com/testforum/gallery/7/468-140411132008-7947276.jpeg" />
Tach Dash
<img src="http://www.stangfix.com/testforum/gallery/7/468-140411132102-79502266.jpeg" />
AC Vents
<img src="http://www.stangfix.com/testforum/gallery/7/468-140411131954-79432151.jpeg" />
Bleeding the brakes
<img src="http://www.stangfix.com/testforum/gallery/7/468-140411132022-79482151.jpeg" />
The stock Air Cleaner is not fitting on the Street Avenger carburetor . Bought some carburetor spacers but they were just a tad too small of diameter to fit.
Put a open element air cleaner on it for now.
<img src="http://www.stangfix.com/testforum/gallery/7/468-180411071843-79761625.jpeg" />
Steering column is in. I have seen searching for almost a year for a Driver side AC Vent with wood grain. I have not seen a unbroken one on ebay.
<img src="http://www.stangfix.com/testforum/gallery/7/468-180411071846-79772214.jpeg" />
Still need to get a passenger side window regulator. The one I got from Dallas Mustang was pre-broken.
<img src="http://www.stangfix.com/testforum/gallery/7/468-180411071848-79782383.jpeg" />
&quot;Fast68back&quot; said:
Whats on the rocker/sill plate, chrome?
It is called an Accent Plate. It is made of stainless steel and is original to this Mustang.
"pre-broken"
That's funny John!
Power steering is in and I hope to get the exhaust on it this weekend so I can drive it.
Passenger side Glass in and the door panel is on
<img src="http://www.stangfix.com/testforum/gallery/8/468-260411130223-80161189.jpeg" />
Hood is on and aligned
<img src="http://www.stangfix.com/testforum/gallery/8/468-260411130225-8019665.jpeg" />
<img src="http://www.stangfix.com/testforum/gallery/8/468-260411130227-8020715.jpeg" />
Time now for the exhaust system , then get it registered and inspected. Julie is ready to go for a drive!
