"Sluggo" said:Those of you that are affected, please click profile then modify then look and layout. Where it says current theme at the top click the word change and select SMF Default Theme - Curve
then click use this theme.
This will make the board more usable for you. Be advised I will be in there changing colors and graphics to try to get our look back to normal.
If you're not affected please continue to use the theme you are using. I can see who is using what theme and can use that information to help solve the issue.
I switched too and the wiiiiide is now gone, using IE. Thanks for you efforts.
