Sluggo: I don't disagree with you, but....
The Original Poster implied that when he examined the voltage coming out of the brake light switch (I'm assuming, of course, that the output line was not connected through to the turn signal switch) he was getting 9V. If that was true, then the turn signal switch is not part of the equation.
The brake switch is an order of magnitude cheaper, both in cost and time to replace, than the turn signal switch. I thought it would be worthwhile to at least explore the chance that it was the brake switch first.
