You must be special...I can access my profile.
"Laurie S." said:Why doesn't my login stick? Just a temporary problem?
"Midlife" said:Cleared cache. Banner only has Home, Help, Moderate, Member Map, Logout. Under User, has Hello, # of PM's, Unread Posts, Unread Replies, My Images, Logout. Could it be because I have Moderator privileges?"Sluggo" said:"Midlife" said:Is this the permanent location now? I have it as: 69.195.124.124/~stangfix/index.php
At the moment, there's no way to access my profile to change such things as the timeofday, avatar, etc.
Yes. It shows that because the domain is not transferred yet. Once that is done it will display normally.
I can access your profile. Tried clearing you cache and sessions?
Not me :-["Laurie S." said:I can access my profile fine.
"Midlife" said:Theme appears to be blue, if that is any help.
I'm not complaining, but I'm sure Sluggo would appreciate knowing about any quirks that appear.
"cmayna" said:No problem accessing my PM's and profile. But losing all my food pics -mg
"DougG69" said:Posting in case any of this is helpful. Which it probably isn't, and in that case just ignore...
Tried to access the site via my bookmark in Firefox, got an error page.
Tried just shortening url to stangfix.com since my old link involved the 'test forum'.
That brought up the site, but I could not log in.
Tried security question (first pet) to reset password, was rebuffed. Tried all lower case. Same result.
Used 'email password' feature to try resetting my old password.
Denied, has to be at least 8 characters.
Used 8+ character PW, which obviously worked. So you guys will just have to continue to deal with me 8)
I noticed I am still showing as not logged in via 'stangfix.com' homepage, but if I click on the Mustang emblem in the upper left it forwards me here (http://69.195.124.124/~stangfix/index.php) and of course I'm good to go.
"Ponyman66" said:"Laurie S." said:Why doesn't my login stick? Just a temporary problem?
Dunno if anyone else is having the same problem, but I too have to log in each time. I tried deleting the old cookies so I had fresh ones, as well as flushing my cache. Same issue each time. Not complaining mind you, just pointing it out to help work the bugs out. Thanks for all your hard work![nb]That will cure itself when the domain is transferred permanently [/nb]
p.s. I also just noticed all of the old message icons are gone (hadn't seen that one mentioned by anyone else).[nb]I'm not sure of what you speak. Please elaborate.[/nb]
