"Midlife" said:Are you saying that while cranking the starter, the engine just doesn't catch, but just cranks over? If you have 6.5V while cranking, then the starter solenoid is not giving the right voltage while cranking. If you have ~12V while cranking, then something is wrong with the distributor/petronix.
Another issue may be that the starter cable has deteriorated, and is demanding too many amps to turn the starter. When this happens, the voltage drops on the battery and then there's not enough voltage at the coil while cranking to fire the engine.
The 6.5 V I measure was just with the key in the "on" position. I might can get one of the boys to help me and measure it while it's actually cranking.
Yes it doesn't catch, just cranks and cranks. I don't know how old the cable running to the starter is but it would be easy enough to replace....
