daveSanborn
Let's try starting from the beginning. You have a lot of info scattered into two different threads. Starting a car shouldn't be this difficult and we're probably overlooking something.
I got my wiring finished last weekend and the car started right up. I started it one time this past week for a few minutes to check the volts at my choke.
Yesterday, I had to take the ground strap on the back of the block off and then put it back on...long story but basically the ground strap was in the way.
Now it won't start. It cracks but just won't fire.
After replacing the engine ground strap and installing a new starter.....
The starter is new and the "clack, clack, clack" sound when trying to turn her over is gone thankfully.
They replaced my battery for free because it was dead. But after an engine build and wire project it's been off the road a lot since about the first of October so that really wasn't a surprise.
The bad news...still won't start. Just cranks and cranks.
I just pulled the no. 1 plug held it against the fender apron and jumped the solenoid and had spark.
I replaced the solenoid since the starter instructions suggested it and the engine turned but stopped as soon as the key went from start to on
What do you mean when you say that the engine turned, but stopped as soon as the key went from start to on?
gave it a try with jumper cables. Turns the motor and cranks it but no fire.
Through ALL of our troubleshooting steps we've found that you DO have spark at the spark plug. Is this still the case? If you have spark there are only two other things that could would prevent the car from starting.... fuel and engine timing.
With the air cleaner removed, look down into the top of the carb and cycle the accelerator rod/linkage. Can you see fuel being sprayed out of the front nozzles? If yes, then the car is either flooded..... doubtful..... are the spark plugs "wet" with fuel?..... or as recently mentioned the engine somehow became out of time. Engines don't jump timing very easily. Isn't this a newly rebuilt engine? If so it should have a new timing chain on it and it's doubtful the chain would have been loose enough where it would have jumped time.
Which has now got me thinking...... Didn't Herb build this motor? Isn't one of Herb's services that he will help get the engine started upon re-installation? It might not be a bad idea to give Herb a call and get him over to the house. It's always good to have a second set of eyes look everything over.
If the fuel situation checks good, there is a recent thread from CMayna on the engine board in regard to determining/setting initial timing.
