AzPete
I would guess at Terry......something about getting his manhood back.....
"70_Fastback" said:How do you guys typically join an engine & tranny, exterior of the vehicle?
I have the 460 sitting on a mobile engine cradle that I made and the C6 resting on my floor jack. I lift up the trans to the block height, but the angles are just not right no matter how much I tilt it, etc., it seems. The T-converter is fully engaged into the pump & the 4 T-converter bolts are through the flywheel holes. But it still doesn't want to go together.
Would it be easier to sit everything on the floor perhaps for alignment purposes? All I know is that it's killing my back trying to lift that trasmission up and wiggle it into place!
"Mach1Rider" said:Verify the converters nose size to crank first, if it is the same use a couple of 4in pieces of allthread screwed into the block for
lining up the trans to eng. It should take a little wigging to mate the block dowls to the trans bell.
Also make sure the covertters drain plug has a hole to go into.
"buening" said:I've also taken some fine sandpaper to the dowels and shinned them up, then apply a bit of lube to them to aid in getting them in. Sometimes the dowels get rusted or dirt stuck to it, making it a tight fit.
the sizes IIRC are 1.850" and 1.835" if you have a caliper you can measure the shout on the TC and the ID of the crank."70_Fastback" said:I think making some threaded dowls will aid significantly.
And the flywheel has 4 large holes, one clocked next to each bolt holt for the drain plug to reside. So orientation of the converter shouldn't matter. The only one unknown is the snout to crank size.
Thanks.
"tarafied1" said:the sizes IIRC are 1.850" and 1.835" if you have a caliper you can measure the shout on the TC and the ID of the crank.
Mark planning to stop by again?"70_Fastback" said:I ended up heavily drinking beer instead, due to some bad news.
