"RapidRabbit" said:Timing cover needs to drilled for the dipstick.
C4's are pretty good trans. What kills the stock one's is high RPM's. If you occasionally romp on it it will be okay. If you become a weekend warrior there are some mods that will make it live. Ford is actually putting C4's in the 2012 Cobra Jet Factory drag cars so they can be dependable."jmbour66" said:Okay. I've decided to go with this 5.0 bored to 306, the engine will produce about 350 hp and now I'm concerned with the C4 stock trans........
Sent from my DROID2 GLOBAL using Tapatalk
"tarafied1" said:C4's are pretty good trans. What kills the stock one's is high RPM's. If you occasionally romp on it it will be okay. If you become a weekend warrior there are some mods that will make it live. Ford is actually putting C4's in the 2012 Cobra Jet Factory drag cars so they can be dependable.
