Daves69Coupe
When i remove the timing chain to get to the cam gear is that going to throw off timing or anything?
It only would if i rotated the engine correct?
"silverblueBP" said:Rotate the crank till the dot on the cam and the dot on the crank sprocket line up after the #1 intake closes (TDC). Take a picture and save it in a safe place! You can move anything you want and when you put it back together, it'll all line back up if you put it back to same places with #1 intake closed.
Not sure If I explained it well......
Facing the front of the engine, cylinder #1 is the left bank, front cylinder."Daves69Coupe" said:where is the #1 intake valve located?
"70_Fastback" said:That's how ya' learn by asking questions. :thu
