I want to make sure I am prepared for Fred's engine/trans. removal, and figured I would start this topic to get some opinions.
Which tools and methods have you all found to make your life easier when going through the removal procedure? Do you lift the engine,trans. using a chain attached to bolts on opposite corners of the engine, or do you lift it from the intake manifold? Do you use a engine leveler or just the chain and engine hoist? How high should the rearend be lifted to provide the necessary clearance?
I just want to make sure I'm fully prepared, and that every tool that is required or that will facilitate the procedure are on hand and ready.
