Modified 1968 Coupe
I spent the weekend working on the gaps on the front end and is now ready for epoxy primer
I finished the body work on the front end and bottom of the fenders and than epoxy primed
I like the looks of it except that lower spoiler. I think I'll get one also, and modifiy it like you did. I might even try to split it like this...
Bill
Bill
now I like that for some reason...
I wanted a plain grille for the Coupe so I ordered a new Dynacorn grille and drilled out the rivets that held the uprights.
Be sure and check out the June 2012 issue of Modified Mustangs & Fords magazine because the Coupe and Fairlane will be on the cover. This is the first time a car not finished is on the cover.
I got a new set of taillights installed. After a lot of trimming on the new rubber taillight to body seal they finally fit.
I installed the grille and trim
I wanted something a little different and I had an extra set of wide grille moldings that I epoxy primed black
I like the black what do you think?
We are going to a car show in Tampa tomorrow. This is a new show for the Mustang Club of Tampa at Davis Islands airport.
