"Phoenix" 65 Coupe to FB
Discussion in 'Member's Build Threads' started by JRANGER, Dec 30, 2016.
  1. Fst Blk
    Fst Blk Well-Known Member
    Some don’t like it but a dusting of wd40 does a great job of keeping surface rust away. Just make to prep it accordingly before paint.
  2. msell66
    msell66 Burning Fossil Fuels as Fast as Possible Donator
    Or a few cans of silicone lube will do it too.
  3. Midlife
    Noooooo! Only use WD40 if you like fish eyes for breakfast, lunch and dinner.
  4. Fst Blk
    I said you had to prep it before paint. A good wax and degrease will cut right thru it.
  5. Horseplay
    Stay away from ANY rattle can stuff if at all possible. If you absolutely must use something go with an etching primer. It has the best "bite" but also can be sanded off easily. If some remains in a spot and gets painted over its your best option to avoid issues.
    When it is time to lay down the "real" base primer (epoxy) you'll want to remove EVERYTHING and get back to bare metal. NOTHING out of a rattle can will give you the level of adhesion you want under final paint. I've used the Eastwood 2k stuff to paint my rear end (easy {.}) and some brackets and such and it is decent but I wouldn't want anything under my paint other than matching product for fear of issues with both adhesion and compatibility.
    I've left metal bare in my garage for months without any surface rust issues here in the Midwest during the humid summer and such. I also would avoid WD40 or any such product on something intended for paint. Yes, you can use a degreaser or such but only one way to know if you got it ALL removed and that will ruin your day 9 times out of ten.
  6. JRANGER
    JRANGER Active Member
    Thansk for all the info guys. Ill let it sit for now and hope to remain rustless
    Merry Christmas to me! KY Mustang had dynacorn doors for cheaper then most, free shipping for me, plus there Holiday17 7% sale means i got a LH door with Brace for $316 shipped
    Grabber70Mach likes this.
  7. Boom
    Boom Active Member
    Any update? Did you get your new door installed?
  8. JRANGER
    I did get the door hung but not alligned. I actually got sick the week it arrived and it has been firgid here sense. So i just ordered a 5000 Watt 240v heater for the garage so i can get back to work.
  9. Boom
    Boom Active Member
    This weather is crazy, I had to wear a jacket for like 2 days, now its back to like 60* though.
    I'm in the same boat with the repro door. I hung it and have the weatherstripping on but haven't messed with aligning it yet.
  10. msell66
    Pa leeze.
  11. tarafied1
    tarafied1 Well-Known Member
    is it like -60 up there Mark?
  12. msell66
    It’s actually warm for a few days. 36 now, but it’ll be below zero again come Friday.
  13. tarafied1
    similar here, 40's and rainy, supposed to be in the 60's tomorrow.
  14. JRANGER
    Its almost 50 today but supposedly we will have freezing rain friday SMH......
    On the bright side my heater and 10/2 romex showed up. Now if the Effin breaker would ship lol
  15. Horseplay
    10/2? How are you planning to ground it? Have you got a sufficiently sized ground run into the garage already? Maybe conduit connected back to the house/grounded panel? Don't take chances, especially this time of year with all the melt, etc. You can get breakers at any big box hardware store. They're cheap.
  16. JRANGER
    Is 10/2 with a ground wire
  17. Horseplay
    Cool. Didn't want you and your car going up in flames!
  18. JRANGER
    haha yeah im crazy just not that crazy. Id die if it went up in flames
  19. Grabber70Mach
    You know 10/2 is only rated for 30A up to 100ft per NEC.
  20. JRANGER
    I have maybe a 15ft run im doing and a 30amp breaker
