tlmartin84
Which coil over kit did you end up going with?
Street or TrackWhich coil over kit did you end up going with?
HF wire is crap. Learned it myself the hard way. Same goes for welders. Until you step up to one of the premier top brand names your welding will be challenged. Plenty of proof of that but we all have to work within our budget constraints. Like with all tools, buy the best you can afford. They cost more for a reason and its not just the label.I hope I'm not repeating something already called out here, but one thing to look into is the wire. I have heard of a few people having poor results until they got some higher quality wire. I got my wire at Harbor Freight and it makes me wonder if that was part of the issues that I've had.
My eastwood is far better but it will lay a good bead i think im having issues just getting my speed right. I did recently switch wire as i was using Hobart from Tractor supply but they were out some im currently using Lincoln wire from LowesHF wire is crap. Learned it myself the hard way. Same goes for welders. Until you step up to one of the premier top brand names your welding will be challenged. Plenty of proof of that but we all have to work within our budget constraints. Like with all tools, buy the best you can afford. They cost more for a reason and its not just the label.
400HP more then likely tied to a 4r70Wnice! what are the goals for the motor?
I was going to ask if you are using icy acetylene or mug but it appears the firstWell i started to tack weld it together but.....i ran out of gas, so i am going to call my.local welding supply tomorrow to see if they have a decent 80cu ft tank.. So i did find a nice little grove full of fiberglass and bondo. Def not stockView attachment 29147 View attachment 29148 View attachment 29149
Purchased an Engine stand and hoist recently from harbor freight as i picked up a 351W to disassemble and have built for the car.
I have the same hoist. Works great. I went with the stand that folds up to save room. Are you going to stroke the engine or just rebuilt it at stock stroke?
You can get 400 hp out of a 351 without stroking. Just let someone help you with component selection. You want stuff that will work together. For something basic like yours a full Edelbrock top end kit (heads, cam, etc.) might make a lot of sense. I have to tell you a 351 in a '65 is a tight fit with stock shock towers. You will hate plug change day!
