JRANGER
I took and tried to clean it with my angle grinder then hit it with weld through primer on both sides of the metal. The inner section has a hole on the bottom too so there is definitely more to be taken care of. Next step i plan to do more cleaning then coat the inside with rust encapsulatorWay better approach to go with the original doors for a ton of reasons. I wouldn't be me if I didn't caution about the need to do a seriously in-depth and detailed effort to remove any existing rust and rot behind the skin in the guts of the door before sealing it all back up. As advanced as it had gotten it will come back very rapidly and eat into the new metal way faster than you expect. What did you do in the rough old metal areas to make sure you will not have the cancer return? It looks really rough where you sprayed that red, I assume, primer. I see some really thin (even holes) metal in areas. That corner brace piece is hiding some serious rust/rot on it's backside and around where it meets the other metal. Hate to see you go through all this effort to only start to see paint bubbles just a year or two down the road.
