Yes, I rolled those beads into the sheet metal. I have a Woodward Fab beadroller now. Those were rolled with a 1/4" die set.
I wouldn't mind a picture or two of that beast. I've attempted beads by hand, and they don't come out nearly as nice!
It's a manual roller:
18" throat depth. Vice mounted.
Link:
http://www.woodwardfab.com/woodward_fab ... ollers.htm
But for optimal beads, it's best to make it a 2 man operation. 1 to crank, and 1 to guide the sheet metal.
I had Kyle -- 'Rusty_70' -- come over and crank the handle and I rolled out the bead lines. Made it a lot easier and a much better finished product. You CAN do it by yourself, but the beads get a little shake only using one hand to guide with.
I hope to squirting some of this, this weekend!
It's a cinnamon color - VERY heave metallic. It's going on the suspension & drivetrain parts.
The frame is getting a satin, chassis black, spray as well.
It's a hybrid. Body will stay patina.... it's too rough to paint. I have found a clear product that can be applied over rust, etc.
Been tinkering with this in the evenings...
I fab'd the grill shell insert out of 16 guage steel - you can kind of see the new steel frame in the pic here:
Right now, they are basically spaced on 1" centers. I may squeeze them a little closer - but won't know for sure until I get one entire side done.
Currently there are (60) .308 Winchester shells shown here (courtesy of :Mark) - I have about another 60 left. I have to drill out the base of EVERY shell to 5/16" diameter and string them onto a 5/16" steel rod - which will get cherry welded to the steel insert that I made from the outer bottom & outer top side.
I still have to tweek the shells and rearrange some for a better visual feel. And cut some to fill the smaller gaps at the bottom.
I have to go to Bass Pro tonight and buy anothe 100+ empty casings to drill out. Fun times on this project. :sarc
Shot some color this weekend.
Primed the frame with a 2K etching primer - which ended up being MAUVE! :wtf It was a nice light purple frame for a while.
After that was coated, I moved on to shoot color onto the previously primed suspension & drivetrain parts - it's a cinnamon gold metallic:
This color is amazing in the sunlight!
Extreme close up showing the depth... LoL
By the time I finished shooting that color the primed frame was ready for top coating.
I used a chassis black but added an additional med. temp hardener. The paint turned out great as well with a nice, though subtle, texture to it. Exactly what I was wanting.
Example of the texture:
I have to finish cleaning the 9" rear - then prime & paint it the cinnamon color and also paint the inside of the lighting holes the cinnamon color as well - which is going to be a pain. I have a small HVLP detail gun that I hope will make that task a little easier.
It looks nice... perhaps too nice for a "rat" rod... It's going to a nice contrast of "new" vs. "old"... that's for sure.
I think my prototype is looking good, thanks. Keep up the good work and make sure you take enough notes for the second one.
I saw a "rat" rod with a gloss red frame and ratty cab and it looked pretty sweet.
Plus that gold/cinnamon goes with the rusty patina color as well.
Paint choice based on color of existing rust. Yep. First time I heard that one.
