tarafied1
I hope it works! thanks for the effort!!!
YES they had a thorough CAT scan!"gotstang" said:Man, that's beat. Looks like they passed the CAT scan, regardless. :lol
"Grabber70Mach" said:Come on Criag that will buss right out. :sur :lol
"tarafied1" said:now ya tell me! JK I will try it :$$$
this tool? :$$$"apollard" said:Usually this one requires special tool #1, which you have already deployed.
"tarafied1" said:this tool? :$$$
"Rubedizzle" said:Hey Folks,
Hate to resurrect an old thread - just attempted this for my self. I built it out on a breadboard ahead of time, and am testing it using some 12V led's currently (although I will be using halogen reverse lights). I have followed the perfected schematic, and am having a weird situation occur, which you might be able to help me figure out.
I am using the 556 timer as stated, and what happens is when I provide power, my #1 light (which is not involved in timing at all) turns on as normally, and there is a delay in 2nd light powering on, and then the 3rd and 2nd lights occilate on and off (when 2nd is on, 3rd is off, when 3rd is on, 2nd is off), and they continue to flash like this, although the power source is constant. I hooked up only half of the circuit (so using one half of the 556 - so it acted as a single 555 timer) and the light being powered comes on as it should, with the delay set by the 100k pot i have used. I have played with the pots, and i have also replaced the pots with 100k resistors, same issue! The pots are changing the timing, however the lights should not be flicking off and on, as the power source is constant.
I've attached a video, please check it out so you can see what is happening, and maybe you can help me figure this out before i build this on a circuitboard.
Thanks folks!
-Mark
