Mach1 Driver
You need to consider retiring, like KBMWRS and that quack Midlife...
Thanks. I'm filling up my cart there. Trying to get everything I might need.Found it! Another source for a quality trunk mount battery cable.
Battery Cable 1/0 AWG ( Size 0 Gauge ) Black - Copper Flexible Stranded - By the Foot
www.batterycablesusa.com
What he said..It should be about 5/8" in diameter. While thick, its also very flexible, as it should be. It's a high count, narrow strand cable not a cheap welding type. Also double insulated so it doesn't require extra protection other than when passing through sheetmetal (use grommets) or if it routes close to exhaust. It will fit neatly in the door sill raceway too. Best part is you can crank until you kill the battery and never worry about it overheating and causing a fire.
Yeah, like when you screw things up big time: you won't worry about doing that again!I'm a big fan of over-kill because I like to do stuff once and never have to worry about it again.
Exactly!Yeah, like when you screw things up big time: you won't worry about doing that again!
