Only if she actually ever starts it. :roll"Horseplay" said:I don't know. That will certainly hurt the gas mileage.
The more important question is: do your headlights still work and function properly?
Like I said, it couldn't be that tough to figure out. Just remember, the best way to learn this stuff is through the frustrations and joys for fixing this stuff yourself. It's not rocket science and you are more than capable if you give yourself the chance."Kats66Pny" said:I had the two cables (battery and starter) on the solenoid on the wrong sides. I had the temp gauge wire on the coil and the coil wire on the temp gauge. So overall, I don't think I did that bad of a job putting in the wiring.... for being a GIRL! :roll
Doug also hooked up my fuel pump so it turns on/off when you turn the key. :thu
Tomorrow they are going to go over the brakes.
Yup!!! :yah
"RustyRed" said:Sounds like you need to purchase the electrical assembly manual, just sayin :roll
That's the clandestine distillery in operation, you twit."AzPete" said:Crap....Midlife is thinking now.....I thought I saw smoke from the north part of town.
"Midlife" said:I gotta think about this. It seems to me that if you put all of the live feeds on the back post where the starter normally goes, and the starter wire on the front post (where the battery stuff normally goes), the car should still crank, provided the solenoid works as a simple switch. It probably needs the front post to be energized as a relay, though, in which case no cranking would be allowed.
that was one of my suggestions to check, to make sure the solenoid was wired right. I would have never thought about the temp and coil mix up though..."Kats66Pny" said:I had the two cables (battery and starter) on the solenoid on the wrong sides. I had the temp gauge wire on the coil and the coil wire on the temp gauge. So overall, I don't think I did that bad of a job putting in the wiring.... for being a GIRL! :roll
Yup!!! :yah
+1"apollard" said:Uh, maybe I'm missing something, but I've gotta go with Mid's reservation. The solenoid is a simple relay, it doesn't matter which terminal the batt / starter cables are connected to. OTOH, it does matter if the S/I terminals are switched.
At any rate, glad it's going now.
If someone has an old one they would be willing to crack open and supply some pics I would appreciate it. We could put this to rest that way."tarafied1" said:The reason I suggested it is because I did it once. It would not crank. I don't know why but if they are switched around it won't work.
"Horseplay" said:If someone has an old one they would be willing to crack open and supply some pics I would appreciate it. We could put this to rest that way.
If you don't mind, break it open (trying not to destroy the inner connections) and post a few pics of the internal wiring/connections."Kats66Pny" said:I have my old one that I removed because one of the posts broke.
