tarafied1
rattle canWhat product are you using to paint the block?
no, it's a 385 series. Same as a 460. The 390 was a FE, 360, 390, 427, 428...Is the 429 the same block as a 390?
yes indeed!!!... If also recall, there is a short cooling hose near the water pump that was pain in the butt to change
good luck and be careful! I'm just mocking up everything right now. Going to set the block in and then put in the trans so I can measure for driveshaft, setup the hydraulic clutch and wire up reverse lights. etc. But it's a challenge by yourself!I'll be with you in spirit, Craig. Tomorrow I drop my new engine and trans in myself. By myself. So expect it to be a pain too!
