RyanG85
Bruno, you put that rusty piece of metal in your car?????? Shame on you.... :no
"B67FSTB" said:Today I mounted the lower reinforcement plate in the rocker panel.
I cut an opening in the rocker behind the quarter panel ( see pic )
took a rod and welded it to the reinforcement plate and guided it through that hole and positioned it .Then I placed a bolt and tighted it to the inner rocker.
After that , I drilled two holes and secured it by two big rivettes .
IMO its very good to hold the retractor of the seat bells.
"crustycurmudgeon" said:Hey, did you find my tutorial on VMF? That's exactly how I did mine. Got lots of opinions on the rivets vs. welding.
Frank
"tarafied1" said:looks great Steve
"LastDeadLast" said:I got the transmission installed today. I tried to use the guide bolt method, but for some reason I couldn't get the transmission in. I ended up installing the bellhousing and then attempting to slide the transmission onto that. Still no luck. I finally got the big idea to use a clamp to engage the clutch and the the transmission slide right into place with no resistance.
I did notice that the new clutch fork is a about 1/2" longer than the old fork.. not sure how that's going to change things, but the slave cylinder push rod for the hydraulic clutch fits in the fork better.
I still need to bolt the shifter back in and tighten everything up, install the driveshaft, fill it full of oil, and install the exhaust back and we'll be ready for a test drive.
Let's hope everything works this time! :hs
-Shannon
"SELLERSRODSHOP" said:riveted or welded, it's only gonna be as strong as the piece of sheet metal that it could pull thru.
Frank
"cmayna" said:Sure seems much easier to just buy a set already made.
Bruno, honestly, i haven't given much thought to a bigger sway bar, i just have newer 67 style lcas, so figured i'd stay with them and 67 strut rods."B67FSTB" said:thats great man.Just one thaught , isn't it better to built a 68 style strut rod ??
I have noticed that they are better when installing a bigger sway bare . :confu :confu
"Midlife" said:Yeah, but our motto is: if it ain't broke, fix it anyway!
Part of the enjoyment of the hobby is to make things instead of buying them.
:stu"B67FSTB" said:Same opinion here.
The rivets just have to hold it in place so you can bolt the seatbell.
by impact , the rivets don't play any major role to hold the force , its the bolt and mounting plate that is crucial.
"lethal289" said:Best part, the 300 dollars i saved can buy a lot of diapers.
