1967 Build called Electra
Discussion in 'Member's Build Threads' started by JRANGER, Mar 12, 2013.
  1. JRANGER
    JRANGER Active Member
    Yeah, i finally said it was time to see if she could go for a long drive...70 miles to lebanon and then back after it warmed up. Not a single problem but i think the steering could be slightly improved if i get that negative camber or caster i dont remember which it was lol. It was awesome, i did also realize how much heat comes out the shifter whole, i mean dman...i need that boot.on lol
    tarafied1 likes this.
  2. tarafied1
    tarafied1 Well-Known Member
    cool, we went to the Nashville flea market today. We almost crossed paths
  3. JRANGER
    Pretty much ready to install. Needs a cleaning and some finishing panels
    Grabber70Mach and tarafied1 like this.
  4. JRANGER
    ok so wired up and installed.. Tested out all the audio and adjusted settings. Good video quality and functiona. Pretty happy with by $200 android radio/gps.
    Now the problem..took her out and took off while.in 2nd...A nasty burning smell showed up and on top of that she was running a bit rough. May just be the gas kn that part but the smell.is concerning and now the rear end which had a small leak has a much bigger one as i found a wet spot in the garage...So i guess i need to pull the chunk....Was already in the cards but was holding off..Wish i would of found out before ordering a 1 wire 100amp alt
    oh also i bed lined the original radio box and put in a cup holder/change bin...cup older prob isnt as functional as it doesnt come out far enough attachment-2.jpg attachment-1.jpg attachment.jpg
  5. tarafied1
    hope it's nothing serious. Is it an 8"?
  6. JRANGER
    yeah its just an 8. I actually have a 3.25 chunk to replace it will and i think i was just burning the clutch up some...So ill prob want to watch what im doing lol
  7. JRANGER
    I replaced the alternator with a 1 wire Power Master 100 amp alt and all flickering is gone. Im guessing the 1g low idle amperage was the issue. On to the rear tomorrow
  8. JRANGER
    FB_IMG_1476025486755.jpg rear end tore apart, naturally parts stores didnt have gasket and seals. So ive ordered them and will upgrade my rear xhunk from 280 to 325 so she gonna have a lil more pep. By hwy mpg lol....
  9. tarafied1
    I'm currently running a 3.25 in my 9"
    its a pretty good compromise, not too much rpm's to hurt mpg real bad but a little more leverage for getting her moving!
  10. JRANGER
    Nice!! What rear oil are you running i ordered some Lucas 80w-90...
  11. tarafied1
    I have Royal Purple 80/90 with friction modifier for the limited slip
  12. scedd
    scedd Well-Known Member
    He He He, he used big block & MPG in the same sentence.:D:D
  13. JRANGER
    20161010_163358.jpg had some rustoleum and figured since it was clean and waiting.on gaskets id spray it a bit
    tarafied1 and Grabber70Mach like this.
  14. JRANGER
    installed the rear chunk and torqued to 30lbs. Pushed the axels in a made sure everything fit right and turned.
    I was going to put the whole rear back together but i decided the drums were old and rusty and needed replaced so since i had everything taken a part i ordered a rear disc conversion for toms classics. 11 discs and was rather cheap. So ill install those when they get here and continue to reassemble the rear.
  15. JRANGER
  16. JRANGER
    Got my auto city classics (Tomsclassics on ebay) rear disc kit installed...It was $250 and had a few gotchas. 1st you have to drill the rotors to fit flush for the countersink. Also it doesnt mention where to put the connector for the brake lines.
    Still have to bleed the lines. Did of course fill the rear with 2.5 quarts gear oil.
  17. JRANGER
    Just found out this kit uses 85 Cadillac Eldarado calipers and pads with 79 Trans am rotors...lol
  18. tarafied1
    weird combo but as long as they work!
  19. JRANGER
    Yeah, i have to bleed the brakes and hook up the parking brake but other then that its done. Probably going to replace the tail housing seal or slip yoke seal or whatever its called before i put the driveshaft back in
  20. Horseplay
    No probably. Do it. Cheap part no reason not to.
