"tarafied1" said:I don't need adjustable unless that makes it easier.
"gotstang" said:Sweet, thank you! That answers all the things I was pondering about the operation. What about if you are turning with the brakes on? I guess it would hold one side and flash the other, because of the flasher unit?
I guess I can forgo getting real fancy with the 4070 IC chip and just leave it as-is..thank god! :rofl
PS: I see you're using electrolytic caps? I pulled a dummy and assumed all ceramics for some reason...which positions are you using the electrolytics for?
Edit: I don't want to ask too much, but what are the values on your caps? The original schematic is poorly labeled. I'll have an annotated CAD'ed schematic and full BOM to share when its over...promise!
:ecit
"gotstang" said:Here's the "finished" version, looks OK, seems to be wired right. I'd like to put resistors in place of the 100k pots apollard is using, but that will probably be trial and error unless craig wants the rate of flash to be adjustable??
"daveSanborn" said:This is some really amazing work guys.... How much money is involved in building one of these sequential flasher units?
a std bipolar trans
"daveSanborn" said:???????????
I'm having a hard enough time following you guys..... and now you've switched gears and have started talking about sexually infected mental illness suffering cross-dressers?
WTF? Did I miss something?
"gotstang" said:I'd like to take a moment to give a shout out to Radio Shack with a heartfelt F-YOU...hookup wire is supposed to be SOLID, if I knew I wanted to spend hours trying to cram regular (stranded) wire into little holes, I wouldn't have paid $7 for the privilege. :rofl
"apollard" said:Buy high quality telephone wire. Different colors, easy to strip, and solid core. Cheaper too :$$$
You can use good quality cat 5 /6 wire in a pinch. But, it's is twisted badly- so I usually buy telephone wire.
