Looking good! Can't wait to put my fenders on and put my MTF nose on.
Looks like fun. Is this all metal filler better then bondo/evercoat? Never used it, just wondering.
I like to use all metal in areas I’ve butt welded to help cover any pin holes I may have exposed in grinding. It has an aluminum powder mixed it. But in the original lead seam areas I’d use something stronger like durabond with fiberglass stain. It will flex better in those areas.
looking good though, that's a lot of contours right there
You need to carve that bondo out and find out what it is hiding. What does the backside look like and the metal in the window recess? This is an area prone to water pooling and rot. You want to make sure it is repaired properly and not left to recur after paint.
Also, when setting your door gaps start with the one between the door and quarter as the quarter is a fixed point. Fender to door comes last. Given the angle of the last pic I can't tell what that rear door gap looks like. What shows is very good.
That lower front corner door rot is normal but still bad. You can bet there is some inner structure that may need cut out and replaced too.
Cut out that door rust and you will see what is going on behind it. There is inner structure that supports the hinge panel, etc. that will likely also need repair. Like I wrote it is very common and the reason so many doors get scrapped. Water can pool in there (debris builds up and clogs drain holes) and cause real damage. Get it fixed now or it will come back quickly.Rust in the door doesnt look too bad except in that corner. As far as the rear it def has some surface rust on the underside in the corners so im going to have to figure out how to get a wire brush in their good and see how rough it is
