janschutz
Corn Hauler
Did you make the pony, I'm looking for the codes to cut one out on our work's Laser table or my son's plasma table.
I get it. I have made the switch and do everything in SS now and those handheld tools just can't do the job. It is really nice to clamp the tool in a bench vise and just walk up, insert a bit of tubing and wham bam double flare done like that. Add in my homemade tubing straightener set-up and I can crank out some lines! Now if I can only remember to put the damn fittings on before flaring every time!I've been looking at their flaring kit. Its super nice looking. I got the cheap kit for now since I'm using the copper alloy lines that are super easy to bend.
and here I was thinking that was only something that I have done!Making the flare and forgot the fitting...sounds so familiar.
Only thing I don't like about that eastwood tool is it can't be done on the car and the sleeve/doe is pretty long so won't work on small curvy bits.
Then on to wiring![]()
That's a fine tool and I was set to buy it until Zray (a high profile poster on another forum) suggested the Mastercool 71475 flare kit. It can be used on the car whereas the Eastwood needs to be in a vice. I'm not sure whats shakin' as far as price goes recently, but I'm guessing the Mastercool is more expensive.You've reminded me I need to order a kit from Eastwood for my (their) flaring tool with the head and blocks to do 37 fittings. Anyone doing hard lines needs to buy their tool. Like their fender rolling tool, the double flaring tool price has dropped considerably. It is a "must-have" in my book.
