LOL. How do you really feel? You do realize the factory built the trucks with an access panel to service the trans from above, right? That huge floor access panel wasn't put there as a design statement. Thinking about doing something is not the same as actually doing it.That lifting the transmission procedure up through the interior is BS
The MC sits back far enough that it will be a real challenge to put in a second crossmember where it needs to be without some real contortions and new issues that would have to be overcome. It would also greatly interfere with access to the MC. It's not like I haven't looked into that approach. I just don't like the ways I've come up with to go that route.
I was only half serious with the line about pulling it out the top. What it would really entail is accessing it from above by making a slightly larger trans access panel which would allow me to shift it back and clear to drop to the ground below. It could be done from beneath but why make it harder? The extended portion of the access panel will be hidden beneath either the bench seat support framework or a custom console if I go with buckets. Either way it will all be hidden until need to get in there and to do so will be very simple and quick.
I plan to have this wrapped up by Monday so let's wait and see how it all goes. Then you guys can be the judge.
