At least his ears won't flop around in the wind!Will you have to hang your head out the window like a dog while you’re driving to see past that monstrosity of an engine?
Mark
Mark
Much of the work of late has been to find a way to get the engine to fit UNDER the hood. Silly as it sounds, the real problem I had with it sticking through the hood was that it didn't stand up taller. When final assembly was possible and accurate measurements made (short of having the actual front clip installed) the results indicated that basically the air cleaners would be all that protruded. Not nearly enough to look "cool" and deal with all the headaches having an exposed engine causes. I could add in some velocity stacks or carbs spacers to raise things a bit more but not really my thing. I decided I would rather find a way to shrink it a few inches and get it under the hood.Will you have to hang your head out the window like a dog while you’re driving to see past that monstrosity of an engine?
Mark
So I caved to the "don't pull it from above" crowd and removed the stock crossmember which was a pain in the ass! It was riveted to the frame to the point it was a structural element. I made a removable crossmember to support the trans but that also didn't interfere with the brake master and pedal linkages. I will be adding another fabricated element in a different area to replace any integrity the frame may have lost with its removal. Right now I have the mock engine and trans in the truck as I was making new motor mounts. When I pull it all out here soon I'll post up pics of everything.What's the story on the transmission mount at the rear? Have you got that figured out?
