A
Anonymous
Guest
How the heck do you adjust caster/camber with that?
BTW, way cool brutha!!
"70_Fastback" said:Caster is set to at a baseline of appx 8degree postive. The caster will change slightly though as the radius arms articulate from their pivot point when the suspension travels up and down.
As far as camber.... you've got me. The kingpin places the spindel centered on the axle boss. No adjustment there...
"silverblueBP" said:You'll really wear the tires when you bring it to the track :naug
"Sluggo" said:Caster is not a wear angle.
"70_Fastback" said:As far as camber.... you've got me. The kingpin places the spindel centered on the axle boss. No adjustment there...
"AzPete" said:The axle has to be bent to adjust this. It was the same on the older trucks, even with the twin I beam Ford suspension. Not many shops can do that today. You can also adjust the way the spring sets but there is very little room for this before the travel path is effected.
"AzPete" said:This is really looking good.
"70_Fastback" said:The frame is slated to get lightening holes on the sides though. About (6) 2" holes down each front rail portion.
