chaser012001
66 408w, TKO600 coupe...in progress
Well its starting to cooperate...
I was also fighting an issue with the brake lights in that...they were always on when I'd hook the switch up. After looking closer, the SSBC adjustable brake pedal switch pedestal was about 1/16" or so too long. I ground it down, reinstalled, and now its working like a champ! The LED taillights from vintage LED's look amazing! Although I'm not sure how I like the sequential setting...thats easy to mess with though.
I then turned my attention to the heater hoses. Getting them on was a bit of a trick to do by myself. Even with pushing the tubes on the climate control back, they kept flexing back inside of the car. I put the handle of my ratchet in to act as a stop, put a little dish soap in the mounting end of the hoses, and off we went. I did elect to hose clamp them in the engine bay vs under the dash. I may switch that up later when I change the water pump to a reverse rotation (serpentine AC) but, for now, I'm going to leave it.
I was also able to get all the door glass in and rough aligned...once i remembered how to do it...it's been a few years. I'll do final alignment tonight and then put the fuzzies in. I'm pretty excited about this part cause its starting to make the car look more final!
The 6 1/2" Alpine R's are mounted to the kickplates, plates installed, and wires ran for that. I also moved the radio circuit to one of the accessory feeds. I'm still troubled by why the AAW radio wire doesnt charge when the key is on and will be looking more in to that in the future. Until then, the accessory feed will work fine.
Lastly, I installed the subwoofer and box. I had to notch a little out of the top of the divider but the rest of my design popped right in. The notch job isnt great and I will be making it prettier in the next couple days. Although you'll never see it since the back of the seat will be covering it but I digress. I have a 10" Alpine Type R in there that will be fed by a Kenwood 1k watt mono amp. I had hoped the amp would be small enough to mount to the backside of the subwoofer mounting board but alas, that's not the case. I had plans to do a hider board on the backside of the box in the trunk area anyway so I'll be mounting it there instead. Probably best for venting the amp anyway. What will bug me is that I am going to be mounting both the mono and 4 channel to that board...and they are two different makes of amp. Again, it's not the end of the world and easily changed later...but it'll be sort of annoying to my OCD.
I re-read Horseplay's post again specifically the part about relaying key'd power on a junction block. I hadnt thought of that. I do have a relay that I had wired in but not in use. I kind of like the idea of moving some switched power-y stuff over to that. I'd probably move the radio, powersteering, and blower over to it initially. Going to think about that one a little more.
