Ponyman66
Yak, yak, yak
Kat there's also details (e.g. various lips and flat spots) on the front edge and that's why I'm doing a pattern to put them back in the patched area. I actually cut mine wider than necessary to put those in.
Regarding Pete's comments, if you look at the piece I made for my car you'll see all the vertical "black" lines. Those are actually the relief cuts in mine so it would bow properly. The color is simply heat marks in the steel from the cut off wheel. You can avoid the relief cuts if you have access to a shrinker/stretcher (something I wish I had and WILL eventually get!). By forming the bow with one of these, once it's formed it's there! I have to weld those cuts up to retain the shape.
BTW, thanks for the heads up on CJ's. I looked at your earlier threads to see any info about where you got yours. Keeping my fingers crossed!
