"70 StangMan" said:I'm impressed....mine just bitches about it :rant until I do it.
"RapidRabbit" said:Now while you're at it you'll end up remodeling the whole bathroom too. One thing leads to another and another.
"Larry G" said:I'm not even mentioning any of this to my wife.
I'd love to but it's not in the budget! Actually none of this was but she got the wild hair..."silverblueBP" said:Change the tub to a walk-in shower!
Plywood (even chip board) is pretty commonly used but you're right, a "concrete" board would be best. The main concerns are flatness and rigidity. If the wood flexes you can get some major issues with cracking of the tile and grout. If the tile and grout are sealed properly (and toilet set right), water/moisture are not really a factor."Grabber70Mach" said:Not 100% sure Craig but I thought the correct substrate/backing for tile was a concrete backer board.
"tarafied1" said:Well I didn't do the concrete so I hope the floor holds up. The budget bath is almost done.
yes she does. I'm quite lucky. Thanks"stangg" said:Looks great by the way... Your wife does nice work.
