3175375
Those are 1970 tail lights. 69 had standard spacing for the chrome pieces.Somewhat. These are 69 lights which are long then the 67 you usually see.
View attachment 30842 View attachment 30843 View attachment 30844
Note: this_feature_currently_requires_accessing_site_using_safari
its a mtf bumper but my mustang is a bit weird everything fits greatNice, who's bumper is that?
Some advice. IF...and that is a very big IF...you buy an engine "from a guy" you'd be foolish not to take it apart and check everything. A full set of engine gaskets is a small price to pay for piece of mind. I have yet to go inspect an engine that was "done right" that was anything short of junk. Without the oil pan, valve covers, intake and other stuff coming off no way to be sure what you're getting. Be VERY careful. Small block Fords are not hard to do right and don't have to cost a fortune to build.
Same goes for transmissions. Anything you buy used plan on rebuilding unless you really do know the guy and the history of it. Nothing worse than yanking it out right away. AOD can get expensive and if you are not really going to do a ton of highway cruising are not worth it. C4 are awesome trans that can be had cheap and you can rebuild yourself if necessary.
The easy part of all this is putting it in the car. You can yank or drop a SBF with trans attached by yourself without breaking a sweat. And in your garage by yourself that is exactly the way you should do it. Just be certain you fully seat that converter before you try cinching the trans up to the engine. They need to go together easy. It doesn't take using the bolts to draw them together.
Nice work, isn't that box going to be in the way though?
So what are your painting plans? Have you got the whole thing block sanded? I would suggest you spend the extra time on this car practicing your prep work because I can tell you from experience you haven't gotten to the point you think you do. What I mean is, there are surely low spots, etc. that will show with paint. Use the longest blocks you can on every panel and when you think you're there...sand some more.
When it comes to time to spray what equipment will you be using? Make sure you have a compressor up to the task. That means at minimum a BIG tank and decent size twin stage compressor, optimally. If your pressures vary or you starve your gun for adequate air volume it will not be a good day of spraying. If you have a spare panel or hood I really suggest practicing on that first. Get the feel for the gun and material you will be spraying. Aside from gun air pressure and adjustments your hand motion, speed etc. all play significant roles in how things go. Practice, practice, practice. Buy some cheap paint and start with it and once you develop good gun control switch up to the paint you will be using and spray out a test panel once more before hitting the car. It's cheaper and better to learn this way. It can get expensive and frustrating correcting problems on the real project.
