5000 watts is about 20 amps. That's a big breaker. It's fine just keep an eye on things. Feel the wire after it's run a bit and see how warm it's getting.
Also got the door allined but my striker is too low. So its soaking in some wd40. Hopefully i can get it loose
View attachment 30713 View attachment 30714
Its up and out as far as it will goHave you tried to adjust the striker out a bit?
Got this USC All Metal filler on the cowl and lead fill areas. Will need more on the top of the qtrs but a good start for now. The cowl area worked real good but i also used a 8" dry wall spreader on it. This stuff is a little weird to spread but it works pretty good. I should of used something small on the back part as i couldn't get it to even out how i wanted
View attachment 30625 View attachment 30624
Jeff,
Cab you try to describe this stuff, from start to finish as compared to normal body filler?
Is it smooth when mixed to spread, or is gooey?
Any pinholes?
How is it when it "kicks", fast, slow?
How about after its hard, does it break into easily like regular filler?
IT's 50/50 on this stuff, some guys swear by it, some say it is a joke..........I am debating on using around my door edges, not sure if I should or if I should go with the Duraglass instead.
oppsVideo?
LOL
