Since we are all apparently sitting around at our computers today, give me some opinions. I found a basic aluminum fuel tank that had the dimensions needed to fit where I wanted it to go. While waiting for some metal bits to arrive trying to decide how I want to lay it all out. As shown below, this arrangement fits nicely between the stock frame rails. The two cylinders are storage tanks for the air ride system. I want ample air so I can raise and lower it a couple times at least before the pumps kick on.
So question. Do as shown? Put both cylinders together on one side of tank? Rotate all three 90 degrees, in which case the tank would be rearward and cylinders side by side closer to the cab. When choosing an option give reason for choice. I want to make sure I am not forgetting some aspect. I can move the fuel inlet, etc. any where really just means more TIG work.
I'm thinking of having the wood bed hinged so it can be raised to show off the handiwork below otherwise none of this matters much.
