Ponyman66
Yak, yak, yak
Looking good Ryan! Nice to see some progress.
"silverblueBP" said:Maybe it's the angle of the pic, but you sure the panhard bar is in the right spot?
"70_Fastback" said:I was kind of questioning that too. Also, I am not familiar with that particular brand either - but does it slide Up/Down on that driver side bracket? Not a fixed mount?
Car is looking awesome too!
"Horseplay" said:It sucks but you cannot put those blue arms on your car. Get them over to a powdercoater and change that color. It will bother you forever if you don't.
"monkeystash" said:It does look weird in that pic. No, it's right on, just like yours...errr. actually it's laying on the floor now because somebody stole (I most likely put it somewhere, now I can't find it) my welding helmet. Here's a side view:
Thanks Jeremy. Look at :Mark 's picture. The black triangular piece is fixed, and the alum rod attaches to that on the driver's side and the rear axle mount on the pass side. My picture doesn't have the alum bar in.
"monkeystash" said:That was TCP's trademark color for years. What really pisses me off is that they just changed their parts to gray. I'm not having them redone; once everything is on, you'll barely see them.
"monkeystash" said:
"monkeystash" said:Had a few extra hours today, so I fit my TCP export brace in. It's a bit too Foose for my taste, but a nice, solid piece none-the-less. I might get it powdercoated black, so it doesn't stick out so bad.
Next, I bolted up the lower crossmember. This one also connects to the LCA for more rigidity. You can see the supplied spacer sandwiched between the crossmember and LCA mount. Pretty cool idea IMO.
"Jonk67" said:Who makes that lower crossmember? I want to add that eventually.
