Fst Blk
Shave your shock towers. That should be gravy enlight of what you have already accomplished.
Bill
Bill
"65-408" said:Brake and fuel lines are done, here are some pics of the way I ran them (down the rocker):
"AtlantaSteve" said:Help me understand this picture...My memory of the car might be failing me, but aren't these lines running directly under the floor sheet-metal? If so, how are you attaching those clamps? If you put, say, a sheet-metal screw right into it, wouldn't they be poking up into the floor-board, like, right into the carpet? Or am I imagining the design of the car wrong?
And just from curiosity, where did you get the line clamps,
Thanks!
"Midlife" said:Where did you find those custom wheel covers? Those are wicked!
"65-408" said:You are correct, currently there is a sheetmetal screw going up through the floor... when I dis-assemble, I will probably drop a button head down thru the hole and tack it in to act as a stud and not disturb the carpet... The clips came from mcmaster (as singles), I cut off a 3/16 and weleded it to the end of the 3/8" to make the doubles...
"AzPete" said:With it sloped now, make sure the carb mounting bolts secure it properly. They were originally set at the correct angle for the original surface which you changed.
