Grabber70Mach
Looking good and good luck on the engine issues.  Keep us posted.
"GTchris" said:I misunderstood the builder the pressure plate bolts were not keeping the engine from turning over. I just used the wrong grade bolts. Anyways, he broke down the engine and found some rust that was keeping the engine from turning over.
It hand cranks fine now. We dropped it back in, hooked up the exhaust, clutch linkage, starter, and alternator then called it a day.
"stangg" said:For what short time it ran in the video it sounds good... Why does the builder have your carb?
	"GTchris" said:
This is interesting, the driver side map light does not turn off. The passenger side works like it should. Don't need the car on for it to work and turns off/on just fine.
