"Dne'" said:Are you going to be having your motor/trany ovehauled or are you just pulling it out to service the engine bay/cowl replacment?
dne'
Just to clean up the bay and repair the cowl. I see no reason to mess with the engine since it runs fine. Although we might go in and check the gaskets and replace any that need replaced, but nothing major. Why mess with a perfectly good running engine. lol I *might* replace the tran with an AOD if I found one cheapish I could use. Otherwise I'll keep the C4 and install shift kit or do whatever needs to be done in order to make the ratchet shifter work properly.
