"Kats66Pny" said:Ya'll are confusing me.
What exactly is suppose to be measured? Where? :shrug
"Kats66Pny" said:Oh something else. Those square area's we took out on the cowl... those were actually pre-cut areas being held on with a few spot welds and smothered and covered in bondo. When I was scraping bondo & paint off I noticed some seams. It seems someone in the past repaired the inside cowl, and half-assed it. It looks like instead of cutting out the rusted vents, they cut the top cowl out, put some thick bondo & coating inside around the vents, because if you look under the dash, its full of rusted holes that were covered up. :wtf
I've always wondered about the two pieces being welded together and eventual rust factor, and how to prevent, or ward off eventual rust between the parts! So are the new parts coated with something? What will you be putting on the new inner surfaces of the the cowl to preserve them? or what is preferred?
"Dne'" said:This is just a far fetched thought~ but I've never seen it actually done, the cowls only serve to introduce forced air into the car while it's running down the street~ do you plan to install AC? however, close off the grilled vent with sheetmetal~ clean up the inside as best possible, coat it/seal it. When I park my stang outside(rare event), leaves just find thier way into that darned grill and they are a pita to get out! I'm surprised the cowls lasted as long as they do! Of course you already have the cowl panel~ eh, just a thought. But I'd like to see a stang without the grill for kicks!
