"abrahamfh" said:Here is the only damage in the engine compartment so far, what do you all think? I really would like to avoid having to cut out the whole front PS apron to repair this but I will if it's the only real correct way to repair this.
That's the same area where Gertrude has damage, except Gert's is a little larger. At one point the battery acid ate through it (not rust), then through the bracket under that. I bought a new apron but I'm like you and I don't want to have to remove the whole thing, so I was thinking of cutting out the bad area and cutting the new apron to match what I cut out and see about getting it welded in.
