AzPete
I have a autometer gas gauge out of my last 66 with the matching sending unit...
added updated list, thanks everyone so much so far!!!"cmayna" said:Craig, what else do you need? How about keeping a running list of items needed.
"tarafied1" said:that would be cool. I'm going to have a fuel cell, will the sending unit work in a cell?
I need the ALT and engine sending unit wiring if he has those.
no I haven't worked with soda before, there is white powder all over the parts. Do I need to wash it off with vinegar and water? Can I prime the parts if I'm going to have them powder coated or wait to see what the powder coater wants to do?"sigtauenus" said:Craig, have you worked with soda before? You have to be sure to neutralize it before you do anything with paint or a coating. I use vinegar and water. The local soda guy will do a whole car for $800-1000, so you should be able to get the engine compartment for $100-200 or so.
Will check with Dave on the wiring, if he doesn't have it I might still have both of those myself. I have a box of old wiring I've been waiting for my car to be 100% done before I send it all down to Randy.
here is the rad sitting in the engine compartment"fordrule" said:hey craig what kind of raidiator are you using for the drag car. janshultz is including a larger 68 radiator with the engine in OKC...we might be able to do a swap if the 68 would benefit the drag car better due to size and fitment. just an idea?
"tarafied1" said:Thanks Sam.
I used a self etching primer from NAPA and then Valspar Industrial/Tractor black paint and painted the brake pedal support bracket. I also painted the pedal, the ends of the pin and the clip with engine paint. I think the assembly looks pretty good. Still haven't heard from back from the powder coater on the dash.
