A
Anonymous
Guest
My plan is to fill it with piranha, don't feed them then put a sign out front on Halloween that directs people to sign up for O care!
"copasspupil" said:Installing a ceiling fan and adding two recess lights to my kitchen table. Already changed the bulbs to LEDs and dimmers
"silverblueBP" said:Been working on a lot of little items since moving into the new house in Ames. The latest and most time consuming was making a storage area in the pool room that will hold most of the garage stuff. I robbed an area 7' deep x 19' long and walled it off. All that's left now is to remove the brick steps and replace with some proper steps that have the correct tread depth and riser heights. I've never understood people that just randomly make stairs that are not consistent.
Before
After
"silverblueBP" said:"silverblueBP" said:Been working on a lot of little items since moving into the new house in Ames. The latest and most time consuming was making a storage area in the pool room that will hold most of the garage stuff. I robbed an area 7' deep x 19' long and walled it off. All that's left now is to remove the brick steps and replace with some proper steps that have the correct tread depth and riser heights. I've never understood people that just randomly make stairs that are not consistent.
Before
After
Finally finished the demo of those crappy brick steps and replaced with wood. I used some deck restore paint that makes them waterproof since it's in the pool area. I wanted to see how it works before I re-do the back patio this spring.
"guruatbol" said:Nice to know.
I am looking into the glass enclosures that open up. I also read that if you cover your pool when not in use it helps the humidity.
Sent from my DROID RAZR HD using Tapatalk 2
"copasspupil" said:Finished the fishing pole mount
"guruatbol" said:That's why you use an electric motorized cover.
